Integration with Privat 24 does not work
Integration with private 24 does not work for individuals . For legal entities it is set up and everything works for individuals no.
OneBox Corp - Інтегратор
Hello, did you register the IP of the box in the merchant settings?
Here should be the IP of the box.
You can use the command "ping domen.com" through the terminal or install the extension in Chrome or Mozilla IPvFoo, which will show the IP of the server
08.11.2021, 13:00
To get started, select in the action in the setting "User from which payments will be created" a user who has access rights to create payments to the selected account.
08.11.2021, 14:33
Sukhanitsky Andrey
Integrator
Thanks for the help.
08.11.2021, 14:41
