Good afternoon. Regularly not all payments get into the BOX.
for example, 12 payments were not delayed in 4 working days
from patterns: these are 2 sources (legal entities) out of 4
I give you a link to the task in which the file with these payments is attached
(at the moment these payments are added by me manually)
https://box.dobroznak.com/admin/customorder/support/20879/edit/
Good afternoon. Regularly not all payments get into the BOX. for example, 12 payments were not delayed in 4 working days from patterns: these are 2 sources (legal entities) out of 4 I give you a link to the task in which the file with these payments is attached (at the moment these payments are added by me manually) https://box.dobroznak.com/admin/customorder/support/20879/edit/
Hello. Specify if you do not import payments for any specific Privat24 action (specify the action index in automations)? I also recommend that you set the checkboxes in the actions "If the client is not found, create it according to the data from the payment" - after all, payments without a client cannot be created.
Hello.
