Duplicate payments are created
Noticed this problem
(test order)
If you go to payments
https://onetos.org.ua/218309/?tabid=5
Click "create"
Specify the data and click several times on the "save" button, it will create several payments
You need to press very quickly) But maybe create 3 and 4, please check
Found this bug when I accidentally double-clicked on the mouse
An excellent solution to the problem is to press 1 time))
You sent several creation requests - several created)
22.10.2021, 16:32
but this was done by accident, the mouse makes 2 clicks, is it supposed to create 2 payments at once?
27.10.2021, 13:59
You saved the form 2 times - the browser makes 2 requests to save it. This is the usual logic of how HTML forms work.
I can modify the protection (to make the button inactive after the first click) - it will take 1 hour.
27.10.2021, 17:08
As an improvement, no need
It's just strange that the accounting system, but allows you to make such mistakes :(
31.10.2021, 16:57
