Integration client-bank FUIB
Интересует автоматизация с банками ?
Нужно делать и получать платежи ?
Хотелось бы автоматизировать всю рутинную работу ?
Тогда вам стоит попробовать последнюю версию OneBox OS! Попробовать последнюю версию OneBox OS!
The client has started using the services of PUMB Bank and wants to set up the receipt of payments through client banking. There is a rest api. What do you need to integrate with One Box?
Need a link to the REST API
27.08.2020, 19:51
https://dropmefiles.com/ayqJ7
27.08.2020, 22:17
OK, here the developers will estimate more precisely.
Probably something around 12-24 hours of improvements.
01.09.2020, 21:28
It all depends on what exactly you want to integrate.
if you make payments from OneBox - then 12h
if still importing payments into the system, then +12h
03.09.2020, 14:16
