How to set up cashback for clients. Example:
1. the client registered on the site, placed an online order, entered the necessary data = receive 3% cashback on your next purchase.
2. The product is at a discount, but this discount is for the next product. Let's say 15%
Task:
1. When performing an action, the client must be credited with cashback.
2. The amount is shown in the client’s card and a discount is made (mandatory or at the client’s request).
3. Actions may be different. Cashback can be performed manually by the manager, not automatically, but it should be simple and fast. And be sure to take it into account when placing your next order.
How to set up cashback for clients. Example: 1. the client registered on the site, placed an online order, entered the necessary data = receive 3% cashback on your next purchase. 2. The product is at a discount, but this discount is for the next product. Let's say 15% Task: 1. When performing an action, the client must be credited with cashback. 2. The amount is shown in the client’s card and a discount is made (mandatory or at the client’s request). 3. Actions may be different. Cashback can be performed manually by the manager, not automatically, but it should be simple and fast. And be sure to take it into account when placing your next order.
Use bonuses (Accounting Tables application). When completing an order, you can accrue bonuses using actions, and you can also write them off in the order (consider a discount).
