Problem with add. process product field. I select one data, and after saving it pulls up others.
BP Dropshipping
https://mobiprint.onebox-system.com/admin/shop/workflow/17/constructor/
at the stage "New order" there is an automatic action "Automatically fill in the values of additional fields of the process products based on the directory", with the help of it the task is solved:
The manager chooses field article (variable: "Layout No."), and in another add. the field is pulled up print (product visual, variable: "Visual (pr)")
For this purpose, the "Visual" reference book was created:
https://mobiprint.onebox-system.com/admin/shop/custom/object/directory/1/
But we ran into 2 problems:
1. Choose any article that ends with a code for 2 letters denoting the color. https://prnt.sc/w3rcqd, click "save" https://prnt.sc/w3reez, and the code with the ending "AZ" https://prnt.sc/w3revx is saved, although it was not chosen.
2. At the beginning of setting up this functionality, a print from our server was pulled into the
Did you set up any automation for this field?
2. At the beginning of setting up this functionality, a print from our server was pulled into the directory. But now for some reason it does not pull, although the link is working. https://prnt.sc/w3rjf4
http://89.19.105.34:81/OneBox_mini/1000/9224/OneBox/WT.jpg
Moreover, if the print is uploaded to the OneBox server, the image pulls. But so far, the server does not allow storing such a volume.
yes it seems to be pulling
18.12.2020, 17:09
Sorry for the delay in reply. under NG orders increased 5 times. Loaded. I will answer soon
29.12.2020, 11:34
Weird. We do not pull up. I'll check now. Perhaps the problem is that the link is not "Protected" by the ssl certificate. (For this reason, I didn’t pull on the outlet, maybe the same here.
22.01.2021, 12:48
Automation can be viewed at these stages (at which I substitute the value and click "Save"):
/admin/shop/workflowstatus/41/action/new/
/admin/shop/workflowstatus/116/action/new/
https://prnt.sc/xftysu - Here are the autom. actions operate on these variables. But I don't see any contradictions.
In theory, they are set up correctly.
22.01.2021, 12:54
In my opinion solved the problem.
Now I will test.
1. I made a link to the image through a secure https channel
2. In ed. The action indicated the fields that need to be filled in according to the directory. https://prnt.sc/xfv2ac
22.01.2021, 13:06
