Action set the instruction for the step. Is it possible to stop adding a statement with the action Stop Execution Under Conditions?
Can you tell me if the Stop Execution action works with the Set Statement action? That is, can I stop adding an instruction to the process if conditions are not met, like this ? Or is it impossible to stop adding instructions?
no, adding an instruction to a stage is triggered when the action is set to the stage and not during the transition of the process to it
16.09.2021, 11:46
