Document links in document templates
Hello. When printing a document, a link to the document in the system is placed at the top of the document. This is unnecessary for the client, and it can also be a problem when there is more than one store, and the link is inserted with the name of another store.
In the template settings, I don't see a line anywhere in the HTML code or in the header/footer settings that would be responsible for adding this link.
Also in the settings there is an option "Show BOX signature when printing documents", it would be logical to disable it, but there is no check mark there anyway, that is, it is disabled.
How can I disable adding a link to a document when printing?
Original question is available on version: ua Максим
This may appear if the print dialog box has a check mark next to Show headers and footers. This is a print setting in the client itself in the browser.
08.07.2025, вторник, 09:53
Горобець Максим
Indeed, thank you. Although it is unclear why the link is visible even BEFORE printing, just when opening the PDF.
11.07.2025, пятница, 14:41
Максим Original comment available on version: ua
