Evaluation of the refinement - action at the "Switch responsible depending on the role" stage
There is an action parameter "Switch responsible if the values ​​of the corresponding fields match:"
I need the parameter to also work with fields with the type "Drop-down multi list"
The action parameter looks for an exact match, or an exact match of values ​​if it is a multi-list and there are 2 or more values.
Example and essence of the refinement:
There is an employee = (Sofia) who has additional contact field 1, 2 (1 is Kyiv branch, 2 is Zhytomyr branch)
There is a process = "A" with an additional field that has the value 1 (in this process, Sofia will also be put in charge, because she has the value 1 in the additional contact field)
There is a process = "B" with an additional field that has the value 2 (in this process, Sofia will also be set as responsible, because she has the value 2 in the additional contact field)
The question is relevant.
Please evaluate the revision.
24.03.2025, 09:44
I'm still waiting for the final evaluation!
11.04.2025, 09:27
