Good day Is there any action that allows you to completely remove deleted contacts from the database?
If not, how much will it cost to complete the action in automation?
Good day Is there any action that allows you to completely remove deleted contacts from the database? If not, how much will it cost to complete the action in automation?
Good day. Deleted contacts are used by the system, for example, developers can be such contacts, so you can't delete them completely. How did it happen that you want to delete your leads from the system?
Not all contacts in the system are useful. For example, someone writes in Viber or Telegram and a contact is created, then it is combined with the client's main card and deleted. So, a whole bunch of such contacts accumulates in the system.
I don't like this idea, after deleting a contact a lot of things that rely on the id of this contact can break. I don't see the point in doing this to delete 1000 contacts from your system.
