The action on the process step does not work: Change the process and step depending on the field values
Here is an example of a task that the system had to automatically transfer to the status Goods in stock
https://balistyka.1b.app/95747/
What settings must be made for the action to work properly.
According to the settings, the task should have automatically changed to the status of Goods in stock
1. if you change the condition to "less than 1" - does it work?
2. are there no actions at the "Goods in stock" stage that can throw an error at the transition to the stage?
16.08.2024, 10:31
Легеза Вячеслав iCOLOR OneBox
ФОП Легеза В.В.
Maksym Vadimovich Tyndyk
i will try
although it's not clear why it doesn't work with 0 if there is such a condition and setting
no, there are no such actions
only the Close action is active
16.08.2024, 11:39
ФОП Легеза В.В.
checked, this option worked
but this is only part of the solution
Please fix it so it also works when set to 0
This is an important point, since it is 0 that we have to process as a numerical value.
16.08.2024, 12:52
ФОП Легеза В.В.
Legeza Vyacheslav
In order to get closer to the desired decision according to the necessary logic, he used a crutch.
I set the condition that the value should be less than 0.000001
But the fact is that you often need to work with exactly 0, as the action suggests.
0 is the same number as all the others.
20.08.2024, 10:17
