When switching to a stage, it gives an error of 500, it is not clear what is wrong.
[file]22300[/file]
When switching to a stage, the procedure that sends a request via the API is activated. Here you can test https://sambag.crm-onebox.com/72970/ by clicking on the "get data via api" button, the procedure itself is here https://sambag.crm-onebox.com/app/workflow/12/ procedure/18/
[file]22300[/file]
At the same time, the API request works, the required data in the box is updated. I don't see any errors in the api logs.
[file]22300[/file]
[file]22300[/file]
When editing an order, you cannot send yourself a request in the API to edit the order; with the first action you block the tables associated with the order, with the second you try to edit them and get an error.
