https://crm.tryalia.com.ua/app/automatization/minute/edit/
[file]22193[/file]
[file]22194[/file]
Automation once a minute - Integration of XML/JSON business processes (Import) Return 1C
[file]22193[/file]
[file]22194[/file]
There is a process that created https://crm.tryalia.com.ua/10095/
[file]22193[/file]
[file]22194[/file]
I have attached a file that we are taking away.
[file]22193[/file]
[file]22194[/file]
There is a product https://crm.tryalia.com.ua/app/product/925/edit/
[file]22193[/file]
[file]22194[/file]
It is in two positions in the file (screen 1)
[file]22193[/file]
[file]22194[/file]
And the order pulled only 1 item, with the price of the second in order of processing. And the number is generally 1.
[file]22193[/file]
[file]22194[/file]
They thought the problem was in the check box When searching for a process product, do not take into account the binding of previously imported items
[file]22193[/file]
[file]22194[/file]
But even with her, the situation is the same.
[file]22193[/file]
[file]22194[/file]
What setting allows you to pull the goods into the order as needed? That is, each position separately.
[file]22193[/file]
[file]22194[/file]
Is this a bug, since the check mark should be responsible for this?
[file]22193[/file]
[file]22194[/file]
[file]22193[/file]
[file]22194[/file]
[file]22193[/file]
[file]22194[/file]
