Is it possible to use the urldecode.php function in the action "Calculate and write value to additional field if conditions are met"
Good afternoon, no. If you need, you can add the possibility of use in 1 hour
04.03.2024, 12:36
Thank you. As long as it is not necessary, it is not critical
04.03.2024, 12:50
