In case of changing the PSU interface, it is necessary to adjust the interface on the mobile device in the same way.
I have a question about the inconvenience of this procedure.
In the case of a significant change in the power supply, it is very inconvenient to copy everything to the mobile interface, and then move the blocks. It also takes a lot of time.
In case of changing the PSU interface, it is necessary to adjust the interface on the mobile device in the same way. I have a question about the inconvenience of this procedure. In the case of a significant change in the power supply, it is very inconvenient to copy everything to the mobile interface, and then move the blocks. It also takes a lot of time.
Ustimenko Igor OneBox production wrote: provide screenshots of exactly what you want to improve
It is impossible to show the inconvenience on screenshots. The bottom line is that it takes a long time to configure the mobile interface of the BP. I have a proposal to assign a sorting number for the mobile interface for the blocks in the PSU.
Ustimenko Igor
