GOAL
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
Enter the OpenCart administrator's office from the task in the box
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
What did:
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
Through the iframe, the block was displayed in the process interface with a link to the OpenCart cabinet
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
But when we enter the account login and password, nothing happens in the box, and the fields with the login and password are cleared.
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
Although when we enter with the same accesses via a direct link, everything is fine, OpenCart allows us to enter.
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
At the same time, if we enter incorrect accesses, it gives an error and the values in the login and password fields are not overwritten.
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
At the same time, if we use the link to the site https://balistyka.ua/ in an iframe, the site is displayed perfectly.
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
Please tell me how to fix this problem?
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
[file]21322[/file]
[file]21325[/file]
[file]21326[/file]
GOAL
What did:
Legeza Vyacheslav iCOLOR OneBox (FOP LEGEZA VIACHESLAV VALERIANOVYCH) wrote: GOAL Enter the OpenCart administrator's office from the task in the box What did: Through the iframe, the block was displayed in the process interface with a link to the OpenCart cabinet
Kharosh
Legeza Vyacheslav
GOAL
What did:
Kharosh
Jokes aside, you need to change the cookies on the opencard so that they have the 'samesite' => 'None' parameter, then you can log in normally. This can be done by an opencart programmer
Department of Care OneBox production wrote: But it's not safe, so maybe you need to do it only for the admin and only for certain IPs, for example, and not for everyone.
thank you sincerely very helpful advice indeed!
Department of Care
thank you sincerely
