block "Information from the directory" is not displayed in the process interface
the information of the "Information from the directory" process interface block is not displayed
here the block https://jaluzi-service.1b.app/127495/?tabid=1 is displayed, which should display information from here https://jaluzi-service.1b.app/app/customobject/directory/2/
probably the block is not displayed on the page because there are not even data headers
Good afternoon. In the reference book, a match is searched for by the value of the column, which is equal to the value from the selected field. In the process, fill in the field that you chose in the settings, fill it in in the directory and then you will see lines in which the values ​​​​are the same
01.09.2023, 15:31
