Need to implement file upload to FTP
https://univer.1b.app/desktop/
There is an action https://take.ms/mpCZB
It is necessary that in this action it would be possible to select a field of the "file" type and upload it to FTP with its original name. Or do the same action but separately for selecting the field with the file.
How many hours do you need to implement one and the second option?
1h so that if an additional field with a file type then unloads it. The original name of the file and so should be taken at the same time. If suddenly it doesn’t, you may need some other setting to do this, but in theory it will work without it.
06.03.2023, 23:10
Account on the card
Donats 1
33 USD from Ihor Ustymenko
07.03.2023, 10:25
.dev
The original file name is not preserved.
27.03.2023, 13:58
Give a link to the procedure where this is done and the task in which to poke the procedure, I'll take a look
27.03.2023, 14:00
.dev
https://take.ms/McnDC
Do you have a selection of files here? I have no)
https://univer.1b.app/33807/ - stage "Upload the file by request from the addendum field and save it on FTP"
27.03.2023, 14:34
Pyatetsky Nikolay Nikolaevich
OneBox Insiders wrote:
.dev
Give me a link to the procedure where this is done and the task in which to point to the procedure, I’ll take a look
https://univer.1b.app/33807/ - stage “Load the file as requested from the additional field and save it on FTP”
there is a choice of an additional field from which to take the file. What's wrong?
19.09.2023, 12:52
Care Department
.dev
https://prnt.sc/0fWicBhXY2cn I don’t have it. I came in incognito or not
19.09.2023, 15:01
