Action Refinement: CSV Product Integration (Export)
Guys, I need help and improvement.
There is an action "Integrate CSV Products (Export)" on the watch crown. I need to pass an "additional product field" with the "Dropdown multi list" type through it, but unfortunately, the first value is displayed in the file (here is an example of a product where I tested https://our-store.com.ua/app/product /26394/edit/?tabid=18).
Can it be improved?
- to include all selected values;
- so that all these values are in one cell;
- to be able to set your own separator (now I need to use a separator in the form of a slash / ).
Thank you!
somewhere here we will add the 47th parameter with a separator for multilists. 1h
Bill?
15.02.2023, 20:31
bu
OK :)
bu
Bill?
Yes, expose
15.02.2023, 20:42
The work has been uploaded. setup example.
03.03.2023, 15:51
.dev
Everything is working. Thank you!
03.03.2023, 16:56
