Synchronization pardon between OS and MVP boxes
Synchronization is now possible for additional help to synchronize the process with another box the id field matches with the id in the client box .
When the task is created for 1Box OS, the format is created for the OS version and is not correct for MVP.
The process in the MVP box is created in another business process, in some id 2 (May 28)
I have reverified, adjusted the OS sides are correct, for example https://integrator.crm-onebox.com/12374/
and in the client's box, the process https://logogroup.crm-onebox.com/admin/customorder/support/126961/edit/ is created for the remote BP ID=2 at the starting stage https://logogroup.crm-onebox.com/ admin/shop/workflowstatus/10/action/new/
fence before the transition to the starting stage of the 28th process, there is no way, turn it over, be kind
26.10.2022, 16:50
