The input price in the process and in the journal is different
In the warehouse there are items purchased at different times at different prices.
After moving positions from one warehouse to another, we have the following problem
In the journal, the write-off price shows one (the one that should be), and in the process and the sales report, it shows another figure (averaged over the balance in the warehouse). That is, according to the journal, it was written off for 1,900 UAH (sale 2,100), and in the process it shows 1,500 UAH and a margin of 600 UAH.
Прищепа Дмитрий
At the same time, with the subsequent sale of positions (the first ones were more expensive), the entry price decreases with each position.
08.05.2024, 22:30
Прищепа Дмитрий
With the transition to the OS, the problem was not solved. I understand that this is a system bug
14.05.2024, 15:27
Прищепа Дмитрий
Please help to solve the problem
15.05.2024, 00:15
Dmytro, good afternoon
we assume that it can be configured with the existing functionality, but it may be that some refinement is needed.
Let's decide one way or the other. An optimistic estimate of 3 hours, a pessimistic estimate of 7-10 if you need to refine or restructure your procurement processes.
18.05.2024, 17:34
Прищепа Дмитрий
Thank you, the issue is solved with one tick in the settings.
21.05.2024, 20:37
