https://cdn.tranzzo.com/tranzzo-api/index.html#introduction - API
We need the ability to send a payment from the Tranzo system service using the specified details of the client's card using an action at the stage. Transfer them to Tranzo and, according to certain parameters (card number, account number), make an outgoing payment to the client both there and in the system.
Is it possible to do so?
Are there any nuances?
How many hours?
https://cdn.tranzzo.com/tranzzo-api/index.html#introduction - API We need the ability to send a payment from the Tranzo system service using the specified details of the client's card using an action at the stage. Transfer them to Tranzo and, according to certain parameters (card number, account number), make an outgoing payment to the client both there and in the system. Is it possible to do so? Are there any nuances? How many hours?
Tyndyk Maxim Vadimovich OneBox production wrote: Do you need to send process payments, or, based on some data from the process, send 1 payment (which will not physically be in the process)?
In fact, payment data is fields and additional. process fields Need payment in progress and then initiating payment in Tranzo
Specify specifically which method of creating payments you are interested in. Because there are several different
Do you already set up the creation of a payment yourself or do you need to evaluate something additionally?
Tyndyk Maxim Vadimovich OneBox production wrote: Specify specifically which method of creating payments you are interested in. Because there are several different
credit payments and the same below using the Tranzo token. In fact, the documentation says that credit is payments from a Tranzo account to a card We need just such Do I need to write in more detail?
credit payments
We need just such
Action development will take 6 hours In fact, the methods differ from each other in 1 parameter - first, the card number is transmitted, the token comes in response to it - and you can already make subsequent payments using the card token (you can make settings for receiving these parameters from their additional fields) The action will be multi-configurable to match additional process/client fields with parameters in the request
Tyndyk Maxim Vadimovich OneBox production wrote: Action development will take 6 hours In fact, the methods differ from each other in 1 parameter - first, the card number is transmitted, the token comes in response to it - and you can already make subsequent payments using the card token (you can make settings for receiving these parameters from their additional fields) The action will be multi-configurable to match additional process/client fields with parameters in the request
1 more point has been clarified. In this action, you can add the setting to make a payment in the process for the amount of the Tranzo payment for the specified wallet. Turn on the setting - creates a payment in Box. Do not enable - creates only in Tranzo. This is due to the fact that we make a general download of all payments from Tranzo and there is a risk of receiving duplicates. But the payment will go through.
Duck if there is a whole download - why then set up the creation of a payment? let it import from the extract Otherwise - setting 2 hours
