Add variables to product description
Hello!
Please evaluate the improvement for the "Description" block in the product card.
What is the idea and the need: I work with different price platforms and send different content to all of them (name, description, price, etc.).
For the "Description" blog (so in HTML format) I want to be able to insert different variables that help to take data from the Box. An example on the screen https://prnt.sc/wgqoeg. On it, I roughly showed what I need in the end: a category in the form of a link in which the product consists (via an additional field), an image of the product, characteristics (via a filter or an additional field).
What is the difficulty in doing the same thing, but with existing automation actions for editing products?
Write yourself imaginary constructions in the description, and then replace them with actions with fields
05.01.2021, 15:26
What automations can change/insert information in the additional field "Description"?
05.01.2021, 15:35
Look at your own project https://our-store.com.ua/admin/products/action/update/edit/ , there are examples of actions with formulas
05.01.2021, 15:49
Maxim, from what I saw, there is only the possibility to insert some value into some specific additional field, and in what place, what format - this value will be - it is not there.
For example: how to insert a link to a product category in the body of the description text (which can change for each card) with the same font, right-aligned color and https://prnt.sc/wgsgdx, and insert this text on the left still on a variable picture?
05.01.2021, 16:24
Then I will answer briefly, so as not to waste your time - in the form as you describe - we will not be able to make variables.
Only when filling out this - please type it up as you need, etc.
05.01.2021, 16:36
It's a shame you can't do that. It's just that boxing has such functionality, but on a different entity: in document templates https://prnt.sc/wgt8fv.
I also did this on CMS Magento. There is such a function as "product card template". I create one template with these variables and bind this template to all product cards.
05.01.2021, 16:58
