The filter in the product filters does not work :)
Here https://baza.cn.ua/admin/shop/products/filters/?filtername=&ok=%D0%A4%D1%96%... %83%D0%B2%D0%B0%D1%82%D0%B8
In the search I write "Between" https://prnt.sc/urxz00
Looking for nothing
I assume that the problem is in multilingualism https://prnt.sc/ury00y
Well, as for me, this is nonsense to find a filter to switch to another language, then already display the search only for the language in which it is only looking
Yes, that's right, the question here is multilingualism. I can find more than 100 such pages. We'll probably fix this in the next release.
02.10.2020, 17:18
Kupriyan Vladislav Valerievich
Baza.cn.ua / Integrator (FOP Kupriyan) wrote:
Here https://baza.cn.ua/admin/shop/products/filters/?filtername=&ok=%D0%A4%D1%96%... the search I write "Mezh" https://prnt.sc/ urxz00 Doesn't look for anything I assume that the problem is in multilingualism https://prnt.sc/ury00y Well, for me it's nonsense to find a filter to switch to another language, then already display the search only for the language in which you are only looking
No, I was wrong above.
There is an exact match search based on the client's revision.
02.10.2020, 17:21
Куприян Владислав Валерьевич
Ustimenko Igor OneBox CTO wrote:
Kupriyan Vladislav ValerievichBaza.cn.ua / Integrator (FOP Kupriyan) wrote: Here https://baza.cn.ua/admin/shop/products/filters/?filtername=&ok=%D0%A4%D1%96% ... in the search I write "Between" https://prnt.sc/urxz00I'm not looking for anything I assume that the problem is in multilingualism https://prnt.sc/ury00y Well, for me it's nonsense to find a filter to switch to another language, then already display search only for the language in which it is only looking for And not, I made a mistake above. There is an exact match search based on the client's revision.
Here the filter is copying the text the name of the filter and does not find https://baza.cn.ua/admin/shop/products/filters/?filtername=%D0%9C%D0%B5%D0%B6%D0... %D0%BD%D0%B0%D1%80%D0%BE%D0%B4%D0%BD%D1%8B%D0%B9+%D1%80%D0%B0%D0%B7%D0%BC%D0 %B5%D1%80&ok=%D0%A4%D1%96%D0%BB%D1%8C%D1%82%D1%80%D1%83%D0%B2%D0%B0%D1%82%D0% B8
although partially found
That is, you made a mistake
It turns out all the same that this is a multi problem
1. Can you remove the filter for another language or somehow add a footnote that the search only works in Russian?
2. I have RBM base language why doesn't it search for RBM ?
02.10.2020, 19:00
1. in the next release
2. was originally ru before connecting multilingualism
05.10.2020, 09:16
I see, well, ok, let everyone wonder why the search does not work
05.10.2020, 11:08
