Tell me, there is a field with the value "CsCart#1071" how can I leave only the number "1071" in this field or write it in another field?
Are there any actions that support string functions? Replacing values, splitting or trimming strings?
Tell me, there is a field with the value "CsCart#1071" how can I leave only the number "1071" in this field or write it in another field? Are there any actions that support string functions? Replacing values, splitting or trimming strings?
Perhaps this action with a checkmark is suitable for you http://i.imgur.com/mE2ldF0.png then you can use PHP functions http://i.imgur.com/pd6FYBz.png I don't know exactly what function to use. Then you need to specify in the action the field in which the number will be written, and in the formula line the desired operation on the field with the value "CsCart#1071"
Ivan, thanks - it helped! Perhaps it will be useful to someone in order for the action to work, you need to insert the variable in quotes, which is not very logical, if you insert it without quotes, it will give an error. In my case, the formula worked: trim('[cscartbp30]','CS-Cart #')
