Please tell me what could be the reason that when we change od. measurement in the product card https://etg.crm-onebox.com/admin/shop/products/80617/edit/#done, this field is not updated in the order https://etg.crm-onebox.com/admin/customorder/ order/38096/edit/?
When the product was added to the process, the unit of measurement established at that moment was recorded in the card. You can edit units of measurement in the product table of the process automatically this field is not updated
When the product was added to the process, the unit of measurement established at that moment was recorded in the card. You can edit units of measurement in the product table of the process [file]12967[/file] automatically this field is not updated
process https://etg.crm-onebox.com/admin/customorder/order/38096/edit/?
procedure https://etg.crm-onebox.com/admin/shop/workflow/12/procedure/54/?status=2
You actually specified the unit of measurement from the product card to copy to the unit of measurement from the product card, and because of this it did not work. I added the field unit of measurement of the product of the process, checked - the value was changed by the procedure
