Using the "Logical Type" field when displaying values ​​in an additional field
Congratulations!
Please help me figure out or find a solution how to use the "Logical type" field when displaying values ​​in an additional process field to show only those that have the value On?
I suspect that the solution is somewhere in the "Formula for displaying search results from the directory for a universal block" field, but I can't understand the principle.
That is, I need to deactivate events that have already taken place, but they should remain in the Directory.
Thank you in advance!
In the filter panel in the directory on the left there is a filter for this field, use it. In order not to filter only open events every time, make yourself a Links application and insert this link there, so you will always go in and initially see only active events
12.03.2025, 13:49
Пчолкін Віталій Володимирович
Група активної реабілітації, Голова правління
In the filter panel in the directory on the left there is a filter for this field, use it. To avoid filtering only open events every time, make yourself a Links application and insert this link there, so you will always go in and see only active events first.
Thanks, but it's a bit different. I need to show only the data that has the Archive field active in the additional process field. The question is - how to filter this data?
17.03.2025, 20:48
Add a new additional field Archive to the process, link it to the same reference book and the field Archive of the reference book. Set 1 there in the starting status, display the additional field in the interface, after that, when searching for another field of the same reference book, only lines where archive=1 will be shown, because the additional field Archive linked to the reference book has 1 in this order
18.03.2025, 13:15
Thank you very much, everything worked out!
18.03.2025, 14:58
