System for oblenergo + gas refueling
there is a non-government department of energy.
first of all, you need to set up a personal account (300+ thousand clients)
pull up the financial part and document flow into the system
payment history
the possibility of choosing a tariff by a client with a personal account
mailing lists
You need the ability to quickly reconfigure the system for refueling - this is the main
Original question is available on version: ru «Один юрист із портфелем у руках награбує більше, ніж банда автоматників»
є dosvіd work with energy for 500k+ clients, get ready to take on the project.
05.09.2022, 18:14
Greetings!
You have very aptly outlined the key points - the need for flexibility and adaptability of the platform to changing business scenarios seems to be especially critical. But all this will work properly only under the condition of reliable data security https://www.05366.com.ua/list/517162 and secure document flow, in particular when it comes to payment histories or processing of personal accounts of clients. As an option, you can consider modern practices for implementing CSI and information protection explained in this material practically and simply - useful for those planning a large-scale digital transformation.
By the way, if you are looking for a team that will not only implement a technical solution, but also help adapt the infrastructure to your needs, you should pay attention to those who already have experience in projects for the public sector or energy. This really saves time and nerves.
13.07.2025, 03:27
