Upload action refinement Fill in the contact card field based on another field
Tell me if you plan to upload to the new version of the refinement of the action Automating contacts when saving - Fill in the field of the contact card based on another field https://prnt.sc/vgo2q2. Thanks
Good afternoon. Go to the box you need - check if it has the necessary functionality. If there is - nothing needs to be done, if not - you need to update.
10.11.2020, 16:13
