https://prnt.sc/v3v4q7 , add a field with the ability to enter a phone number for the client in the order
the number must be stored not only in the order, but also in the contact card https://prnt.sc/v3v632
https://prnt.sc/v3v4q7 , add a field with the ability to enter a phone number for the client in the order the number must be stored not only in the order, but also in the contact card https://prnt.sc/v3v632
Hello Try to open the settings of the "Process Contacts" block in the interface settings of the desired status, on the right side you will see a list of fields that are displayed in this block http://joxi.ru/Rmz9MgpuYzPgvr check the box next to the "Phone" field and save the settings. This field will be added for output in the block you need
Hello
