Есть необходимость создания своих уникальных PREG выражений для проверки полей? Это доступно в последней версии OneBox!
Установить последнюю версию OneBox OS
Please tell me how the checkmark in the card of the additional contact field works
PREG expression to check field value
and show an example expression template for this function to work
[file]11140[/file]
Please tell me how the checkmark in the card of the additional contact field works PREG expression to check field value and show an example expression template for this function to work
You can enter a regular expression in this field. Before the new value is stored in the field, it will be checked, and if it does not fit the given condition, an error will be generated for example, in the "PREG expression for checking the field value" is written: /number\s+number\d+/uis for the value "number 1" - there will be an error, and for the value "number No. 1" - there will be no error and the value will be written in an additional field This setting is not only in the additional fields of the contact, but also for the additional field of the process and the additional fields of the product of the process have this setting
Maria OneBox production Employee wrote: You can enter a regular expression in this field. Before the new value is stored in the field, it will be checked, and if it does not fit the given condition, an error will be generated for example, in the "PREG expression for checking the field value" is written: /number\s+number\d+/uis for the value "number 1" - there will be an error, and for the value "number No. 1" - there will be no error and the value will be written in an additional field This setting is not only in the additional fields of the contact, but also for the additional field of the process and the additional fields of the product of the process have this setting
Thank you, Masha now to try where can I see the rules for writing PREG templates in OneBox?
Maria
OneBox production
Thank you, Masha
now to try
This field uses regular regular expressions. You can use https://regex101.com/ to test your expressions In places where non-standard PREG expressions are used (for example, the Turn a letter into a process action), an explanation about the use is indicated next to
Maria OneBox production Employee wrote: This field uses regular regular expressions. You can use https://regex101.com/ to test your expressions In places where non-standard PREG expressions are used (for example, the Turn a letter into a process action), an explanation about the use is indicated next to
Thanks!
Maria
OneBox production
Thanks!
