In the order to the supplier, you need additional expenses
yakі will be in writing in warehouse operations in the sum of the purchase of goods
Butt in the order - two positions
1. -100 UAH
2, -900 UAH
I add. expenses (Delivery + bank commission for payment) 100 UAH
What is required in warehouse posting
1, -110 UAH
2, -990 UAH
Implemented in 1s
Є services and tick https://prnt.sc/w568xn
І in the table of goods it is written https://prnt.sc/w569le
How tse robiti in SRM?
In the order to the supplier, you need additional expenses yakі will be in writing in warehouse operations in the sum of the purchase of goods Butt in the order - two positions 1. -100 UAH 2, -900 UAH I add. expenses (Delivery + bank commission for payment) 100 UAH What is required in warehouse posting 1, -110 UAH 2, -990 UAH Implemented in 1s Є services and tick https://prnt.sc/w568xn І in the table of goods it is written https://prnt.sc/w569le How tse robiti in SRM?
Rostislav - it is recommended that the clients receive the following order: 1) work on the additional field for the product process with a tick Vrakhovuvati in the margin 2) enter this field in the table of goods in the process 4) at the stage, or at the procedure, enter the statement "Record and write in the dodfield, so that your mind will be saved" - write the formula, so that you will need to write down the sum of goods in the dodfield in the process, including the actual sum of the goods. 5) copy the field data to the price of the goods and work on the acquisition of this field (I recommend taking the price of the sale) goods were sent to the warehouse at a higher price. if it didn’t make sense to you here, then forget about the paid service of the integrator, win now.
integrator wrote: Rostislav - we recommend that clients solve this issue as follows: 1) make an additional field of the product of the process with the Include in margin check mark (if the process is incoming, it is possible without a check mark) 2) display this field in the process goods table 4) at the stage or in the procedure, you display the action "Calculate and record in the additional field, if the conditions are met" - prescribes conditions and a formula that will record in the additional field of the process goods the amount you need, including the existing amount of goods. 5) copy the data of the field into the price of the goods and make a posting from this field (I recommend taking the Sales price) then the goods are shipped to the warehouse already at the total price. if you don't understand something here, please order a paid integrator service, he will set it up.
nice solution that really works https://youtu.be/ykrZtAX0PP4
