From which IP addresses are sites parsed? How many of them are there, is there a way to bypass parser robot blockers?
Good day,
I am interested in the module, but no information on its capabilities is provided. Is it possible to get detailed information?
1. From which IP addresses are sites parsed?
2. What is the number of IP addresses and can it be changed?
3. Is there a way to bypass parser robot blockers?
4. Is it possible to adjust pricing conditions depending on the data received by the parser? For example, 1 product is sold on 4 different sites, you need to take the lowest price among them.
Пятецкий Николай Николаевич OneBox Insiders
Insiders - OneBox
Good day.
1. Parsing occurs from the IP of your vanbox; if necessary, third-party IPs can be added through modification.
2. Discussed individually depending on your needs.
3. At this stage, you can connect the cloudflyer service to bypass blocking, but if necessary, you can modify additional services.
4. Of course, this functionality can be configured in the vanbox itself, you just need to talk through the exact logic.
19.03.2025, 14:48
