fix vendor setting when adding a product to a process
there is a product https://box.e-zoo.com.ua/admin/shop/products/37065/supplier/ it has only one active supplier http://prntscr.com/up6nnd
problem: when adding a product to an order through the "Search for products" block, the product is marked with a supplier marked as inactive, while the checkbox "Select an active supplier if no specific supplier has been selected" is enabled http://prntscr.com/up6ptx
here is the test process https://box.e-zoo.com.ua/admin/customorder/order/1392157/edit/
please correct or explain why
Hello, the active supplier is the one marked in blue in the list of product suppliers. Such a supplier is marked in blue after recalculation of prices and availability. Looks something like this https://prnt.sc/up7fuf
28.09.2020, 13:25
