Upload to autopro will be created in the wrong format.
You have the ability to rename the file to .xls in the upload, for example. The upload action itself generates an xls file, it’s just that its name with xml is written in the integration, while nothing prevents uploading an xls file under the xml extension, since there is such a thing as checking the file type by mime type, but that’s another story) just rename the file in the upload settings (on the 3rd screen)
12.07.2022, 16:08
anonymous hamster
OneBox production wrote:
Here it worked.
Can you tell me if it is possible to disable the unloading of goods that are not in stock?
12.07.2022, 16:16
By default, no, but it can be modified in 1 hour. The export action will have a setting to only upload in-stock items. Do you have an invoice for revision?
12.07.2022, 16:20
anonymous hamster
Not yet needed. Non-default auto pro doesn't load items with quantity column "0".
1 more question:
When I add a new upload, a new action is automatically added to the automation.
On the screenshots, he showed that he added a new unloading and the action was duplicated
Is that how it should be? If so, how then to understand which action belongs to which unloading?
If not, should they be removed?
12.07.2022, 16:28
If the correct unloading is immediately selected in the action, then yes - everything is ok.
12.07.2022, 16:42
thanks for the help
12.07.2022, 16:45
