Needs improvement urgently. Price rounding.
Rate the improvement.
1. There is a price rounding setting. It rounds up the selling price.
http://joxi.ru/12MgE0gskXY1Kr
It is also necessary to round the price of the product after applying the discount http://joxi.ru/4AkL5xLUk19Kwr
2. You need a setting for which processes to apply rounding.
http://joxi.ru/5md14Z1t81M0G2
Like this http://joxi.ru/RmzB1lBUMGzOZm
Farkhshatov Rodion
http://joxi.ru/brRgJbgsOVpz9m
15.10.2020, 14:14
Give answer. Rate the revision
18.10.2020, 03:17
it will be cheaper to do it in the procedure for 2 hours
18.10.2020, 17:01
Can you be a little more detailed? On procedure rounding off or both points?
Will the amount or discounted price be rounded?
19.10.2020, 02:02
Farkhshatov Rodion
a new action will hang on the procedure in which the choice is which field and how many characters to round
in your case, you will need to round the discounted price
20.10.2020, 03:03
perhaps at least an hour to meet? It seems that one field needs to be rounded
26.10.2020, 10:42
Farkhshatov Rodion
after rounding, you need to make recalculations
and the action itself must be done
less than 2 will not work
26.10.2020, 10:53
and such a procedure will not load?
26.10.2020, 11:11
Farkhshatov Rodion
I think no
because the update will be done without triggering events
26.10.2020, 11:54
Tell me, will the rounding settings apply to rounding?
02.11.2020, 13:59
Farkhshatov Rodion
depending on your wishes, if you need to distribute, then add
02.11.2020, 15:52
Ustimenko Igor
OneBox production wrote:
Farkhshatov Rodion
Hello! Can you please tell me what kind of improvement was made on this task and how to find it? We have a similar problem and it needs to be solved urgently.
21.07.2021, 20:43
Ustimenko Igor
I want to get back to solving the problem.
Found that the discounted price is still rounded.
The amount without discount is also rounded.
But the cost in the item line is not rounded.
Why is that?
22.07.2021, 03:32
