Lending button from Ukrssibank
Good afternoon, please specify where and how the loan is issued and where the data of the old FOP is visible there? I can look at the place in the code that is responsible for this and say how you can change the data
01.10.2020, 16:03
On our website, when buying, there is a 0% credit button. Clients come in and apply for a loan.
We need to disable this button and then replace it. This is the wrong button under someone else's FOP framed. How to remove or disable it?
01.10.2020, 17:27
They called from Ukrsibbank.
01.10.2020, 17:27
It will take about 2 hours to remove the buttons related to credit/installment from your site. In the finalization, it will be necessary that you accurately indicate all the places where it is so that the programmer does not miss anything. If you already have another button that needs to be replaced with the current one, then let us know - it's better to replace it right away than to remove it and then program a new one.
01.10.2020, 17:49
Another button is in progress, it will take up to 2 weeks
02.10.2020, 09:11
Well, then you need to remove this one so that the wrong loans are not ordered on the site and then add new ones. Within a few hours you will be billed.
02.10.2020, 10:12
And how much will it cost to replace, please send an invoice for a replacement
02.10.2020, 13:14
It is not clear which button to change to and what functionality will be there. You can evaluate only after providing what needs to be exchanged
02.10.2020, 13:17
