Price recalculation and availability
Describe what I mean by these checkboxes https://prnt.sc/ui9yq4, path: Other->Price recalculation and availability
The system has a price recalculation functionality. When a markup is applied to the purchase price of a product, according to the markup rules created (here is information about the work of recalculating the price https://youtu.be/uLqFbmxunaA )
Accordingly, the checkboxes that you have specified will trigger the recalculation of prices for goods after certain actions (after the information about the suppliers of the product is updated, after changing the balance of goods in stock, etc.)
16.09.2020, 17:05
If you change the purchase price of the goods, will the price be recalculated?
16.09.2020, 18:14
If you manually change the purchase price, then no.
You can also use the hourly automatic action "Price recalculation" https://prnt.sc/uif7g7 and select the time at which the price recalculation should be performed.
16.09.2020, 19:40
