error creating check
Hello, when you try to go to the stage at which the action to create a receipt is set, after a pause, an error appears without comments and the transition does not occur, please clarify the reason and solution, action settings:
Similar problem
https://crm.mebelok.com/
02.01.2022, 15:34
Does Checkbox itself work exactly? Skorish for all the problem itself is there.
02.01.2022, 15:58
yes, I checked, the check was created through the Checkbox account
Sidorchuk Valentin
02.01.2022, 16:13
Sidorchuk Valentin FOP Sidorchuk Valentin Garievich wrote:
https://checkbox.ua/ru
read the title on the API site - there was an error reported on 1.01.2022 that the service had crashed and was fixed for 3 days
03.01.2022, 10:38
