Put a discount on the product depending on the value of the field
Example, there are several process products in an order
The product has an extra field. If in addition the field contains the value "Gift" (example), then the product is affixed a 100% discount
Please advise how to set up
There is a similar action "Write value in the process product field" - it can write a field with a % discount.
You need to modify the condition for matching the additional field of the process product to the value in it. This revision will take 1 hour.
28.09.2021, 17:24
