Need a consultation about the "Add products from one process to another"
1. In the process, add 3 products and write "Add products from one process to the next" copy to Batkivsky.
2. In the course of the year, you need to take all 3 goods, yakі є in the same process from the Batkіvskogo і add in a new tіlki tі, yakі vіdpovіdat minds (1).
3. In another hour, you need to pick up one item from the Batkivsky.
I add and take away from Batkivsky with the very same thing. Ale, when vikonannі p.3, the rest of the goods are taken away, but the replacement of the new one is given two more.
To help you to improve that when vikonannі p.3 did not add zayvі commodities.
I recorded a video to make it clearer: https://take.ms/rtU4r
Tested on orders https://ob.fo.co.ua/admin/customorder/postachannya/109739/edit/
Tweaked the procedure to add https://ob.fo.co.ua/admin/shop/workflow/23/procedure/63/?status=0
i to pick up the goods https://ob.fo.co.ua/admin/shop/workflow/23/procedure/48/?status=0
"I misunderstood what works and suits us:
I put the mind in diї, so I take positions: https://take.ms/VvBta
now, it's an empty field in the contract: https://take.ms/HCtJz
then the stinks and get from the Batkivsky, not giving up the rest.
thanks for the help. "
here, through a partner tech support, they took away the report, closed
21.05.2021, 15:14
