Good afternoon. At the moment, automation is working. The work of automation scripts can be viewed from the application "Server load control panel" https://box.inal.com.ua/app/system-statistic/
Tasun Sergey Vladimirovich OneBox production wrote: Good afternoon. At the moment, automation is working. The work of automation scripts can be viewed from the application "Server load control panel" https://box.inal.com.ua/app/system-statistic/
Automation "Integration of Business Processes XML (Export)" should upload the file inalweborders.xml to FTP. But the file does not appear, so I concluded that the automation does not work. What could be the reason? FTP is available, no settings have been changed.
Zagidulin Nail Nailevich wrote: What could be the reason? FTP is available, no settings have been changed.
FTP is not available from the box server.
If you need to set up a server to fix a problem, please submit an invoice. We make server settings only for OneBox production. Therefore, you have all the information who, what and when set up. Please do it today, as the import of orders in 1s does not work. Stopped work.
If you need to configure something, then on your FTP server. It is necessary that your FTP server allows you to connect from the box server. Right now, the FTP server is not accessible from the box server. When you open access to FTP, everything will work.
Tasun Sergey Vladimirovich OneBox production wrote: If you need to configure something, then on your FTP server. It is necessary that your FTP server allows you to connect from the box server. Right now, the FTP server is not accessible from the box server. When you open access to FTP, everything will work.
Understood. FTP technical support replied that today the IP address is blocked all day due to the fact that within 1 minute up to 90 connections can be made from one IP, more than 1647 were made from the specified IP. This behavior is regarded by the server as an attempted DDoS attack. Last firewall block entry: "135.181.96.51 # over 1647 connects to port 80,443 20230221161201 - Tue Feb 21 16:12:01 2023" The blocking is removed after 1 hour, but then the limit is exceeded again and the IP is blocked again. Can you tell me what exactly in BOX creates these connections?
Understood.
