If you create a new pledge, then when you add the goods to the box, you don’t get to the new one, but to the old one, from which the “make a pledge” button is pressed
Axis I create a new project, I choose a product: [file]17706[/file]
After pressing the "cat" button, the goods can be hit in the cat (upper arrow). The number of wines falls into the old zamovlennya (bottom arrow)
[file]17707[/file]
If you create a new pledge, then when you add the goods to the box, you don’t get to the new one, but to the old one, from which the “make a pledge” button is pressed Axis I create a new project, I choose a product: After pressing the "cat" button, the goods can be hit in the cat (upper arrow). The number of wines falls into the old zamovlennya (bottom arrow)
