Good day!
Process example https://kiyservice.1b.app/97229/
it contains 4 products
I need to create a separate subprocess for each product
Tell me what actions can be taken to do this, or if it is not there, then is it possible to improve it?
Good day! Process example https://kiyservice.1b.app/97229/ it contains 4 products I need to create a separate subprocess for each product Tell me what actions can be taken to do this, or if it is not there, then is it possible to improve it?
Good day!
Thank you!
Made it based on your screenshots
separate processes are created, but all the goods that are in the main process are still added
here is an example https://kiyservice.1b.app/97229/ the main process and if you go to the subsidiary https://kiyservice.1b.app/97694/, then all the products have been added to it
here is the procedure where I set everything up https://kiyservice.1b.app/app/workflow/58/procedure/241/
I will be grateful for your help
Dmitry wrote:
There is an action "Add products from one process to another" https://prnt.sc/jnNdzUX1iRqP https://prnt.sc/rZJ1U-itBuIm should help.
Good afternoon! Here are my action settings https://prnt.sc/bfRNU2eHU2Qc https://prnt.sc/4vNvONDcqexi
