Add. field with type multilist of contacts
There is an additional field.
Field type: multilist of contacts.
one.
The process manually selects multiple values in this field.
Then when creating a subtask,
all selected values of this additional field are automatically copied to the subprocess without any problems.
2.
Some work is done in the created subtask,
this additional field is adjusted... for example, more values are added there.
3.
Now if you copy this additional field back to the parent process using one of the following actions:
"Copy the values of additional process fields to the parent process"
"Copy field value to parent process or specified process",
then in the parent process the values of this additional field are not updated.
And if in will give birth. process clear this field
and then copy again from the subprocess to the parent,
then only the first value of all those that are in this field in the subprocess is copied.
___________________________________
Those. when creating a subprocess,
all v
hello, at the moment these actions copy the value of the additional field without regard to its type, i.e. always copy the first one found
we have taken this issue into consideration, I will let you know about the decision
08.04.2021, 11:33
we can add accounting for the type of additional field Multilist for these actions in 1 hour as a revision
09.04.2021, 17:18
Hello.
What about the second part of the question:
in order to assign several values to this field with the multilist action type?
So that each time it would not be necessary to manually select these values.
Those. it will be some initial set of default values. And employees will change it in the process of work.
Is it possible?
So far, what I have found is that only one value is assigned through the directory
(using the action "Fill in an additional field based on additional fields and lookup data").
12.04.2021, 09:21
Darya wrote:
Hello.
Is it possible?
In 1 hour, you can modify the action Write value in the additional field so that you can enter contact ids there separated by a comma (or a comma with a space), if the type of the additional field is Multilist of contacts
12.04.2021, 18:31
Okay, let's do a fix.
16.04.2021, 12:12
Those. You also need copying by action from process to process and the ability to set several values by action.
16.04.2021, 13:04
