When creating one and the same process with the same stage, different direct duties
At the creation of one and that process
№1 https://rovo.org.ua/admin/customorder/order/980788/edit/
№2 https://rovo.org.ua/admin/customorder/order/980412/edit/
with the same step,
different direct duties to enter
https://prnt.sc/10kfguk
https://prnt.sc/10kfi9v
Ritual when folding
One copying by hand (here you see the bindings correctly)
Another copy for help DII https://rovo.org.ua/admin/shop/workflow/5/procedure/99/?status=0
Process amount
№1 https://prnt.sc/10khy6v with positive values
No. 2 https://prnt.sc/10khz57 with a minus
sales process one and the same process, one stage may be the same (Z plus)
sho vipravini DІЇ (https://rovo.org.ua/admin/shop/workflow/5/procedure/99/?status=0)
what would be a plus?
food rishiv himself
Simply by adding to the dialog "Change process direction Changes the order from incoming to outgoing or vice versa ()"
15.03.2021, 09:39
